DIY Senior
- Aug 25, 2022
- 23
Hi all,
I need a logic check on my compression calculations for my new battery builds. I am building 2 24v batteries with the new EVE MB30 306ah cells. These are going into a RV so I am limited by space constraints. I plan to use 1 enclosure with 2 parallel packs of 8 cells clamped with 1 compression plate using 9 rods with die springs. With 1 battery I would be looking for about 674 lbs of force spread across 6 springs or 112 lb load each but since I am trying to compress twice the area don’t I need twice the force? That would work out to a load of about 150lb per spring across 9 springs if evenly divided or do I need 112 lb on the outer springs and 224 lb in the inner 3? Which logic is correct or is the answer neither? My late night thinking could be being affected by lack of sleep and 1 too many beverages!
Comments and corrections appreciated! Thanks
