jamesinkster
- Jun 7, 2021
- 3
Hi,
I have a truck camper with 280w solar, a Renogy Rover controller, a 200AH LifePO4, and a PD4645 converter.
The PD4645 is a few years older and does NOT have the jumper that will run it in 'lithium' mode.
The camper is usually not on shore-power, but it sometimes is for a day or two before leaving on a trip (mostly to get the fridge cold).
Is there a way I can make things work with the PD4645? I'm nervous because it occasionally runs an equalization mode...
Is there some kind of device I could wire inline that would regulate voltage or basically shut off the charging circuit when the voltage is higher than an acceptable range?
Surely someone else has figured this out?
Thanks
Thanks
