CVCPJared
Ok, I've read probably 40 grounding threads on here, watched some YouTube, read some articles, and have a plan. But my comprehension is pretty low, so I'm hoping to get advice from some of the experts whether or not I'm missing something
So exhibit A: rough layout.
So, those tiny little rectangles on the house and shed are main panel outside the house and "service panel" inside the battery shed that will feed the main panel. There's about 20ft between the house and shed.
The house has an Ufer ground (I beleive it's called), 20ft steel rod in the concrete or something like that. Exhibit B.
This is off-grid. AHJ says i need a seperate grounding rod for a seperate structure (shed). My intent is to make it West of the shed, between the shed and panels, tie both of those into it. Now from the little I comprehend, in a theoretical lightning strike, lightning hits some random spot near the array, and let's say 200,000 volts goes into the grounding rod, and that same strike maybe puts 100,000v into the Ufer ground further away. What I understand is that since those are connected through the equipment, and there's a 100,000v difference, it wants to shoot said electricity through your MPPT, Inverter, and panels, to the Ufer Ground. Is that correct or completely missed the boat?
So the theoretical solution for that is bare copper wire connecting the 2 earth grounds. AHJ is not requiring this. Is that correct and should I do that or am I way off base here? If that is done, does that mean SPD are not required/beneficial at that point, or is this a "throw the kitchen sink at it" situation where the ideal solution is try everything and hope something works?
Thanks for reading the book and for your time!
