I have 18x 450w 48v panels on my roof.
This growatt 12kw inverter of mine has 2 charge controllers. I am presently using them both with 9 panels on each one.
Spec sheet on this says max PV charge current 120 amps. It has 2 charge controllers.
Question: Does that mean the throughput on each charge controller is 60 amps, or both are rated for 120?
Prime reason for asking this is we live in a windy area and I am tempted to run a set of wind turbines to supplement power usage at night. Unless I'm missing something, there isn't a good way to mix in the turbines with the solar panels, so it would need to be one charge controller solar and one charge controller wind. BUT I also want to make sure that the solar isn't getting wasted through a charge controller that can only digest half of what it is being fed. OR... can I just bypass all this insanity by adding an external charge controller for wind only and just feed it right into the battery?
