israndy
- Oct 13, 2019
- 19
So the Valence built-in BMS does cell balancing, and if I connect two together via the communications plug the two batteries will do cell balancing across both units? I read somewhere that the communications doesn't happen unless you have a terminator on one end and I assume the BMS on the other. Is this true?
Looking at the Valence output it looks like they don't do cell balancing but string balancing, can anyone confirm?
What other things does it do, not temp protection I see, but does it to over/under voltage or over current protection?
And the big question, WHY does Will NOT recommend the XP? On his Youtube video for the RT he specifically calls out the XP to avoid.
