Hedges
I See Electromagnetic Fields!
- Mar 28, 2020
- 20,535
Low C rate isn't what would cause damage, sitting for a long time at high SoC is what would cause damage.
Charging several cells at a time to 3.6V and then letting them sit while charging others sounds like unequal treatment.
Charging all in parallel to 3.6V seems better.
Why not charge all in parallel to 3.5V or 3.4V? Lower voltage, much less degradation. You have time on your hands, so can sit a long time at 3.4V to let them trickle up.
No reason to get to a high SoC before building a series pack with BMS, at which point you'll use them, get to a lower SoC, and then recharge to some (possibly lower) SoC.
