Solarfun4jim
Solar seduced :-)
If top balancing an 8 cell x 280AH pack in parallel with a bench top power supply(10A output), setting the voltage to 3.6v and knowing it will take several weeks to charge the pack to that point(im in no hurry), what harm can be done to the cells if the pack is left for 24hours, still connected to the supply after the pack has reached 3.6v and the current has dropped very close to zero? I'm presuming the 'floating' at 3.6v for an extended 24hour period, wont cause much harm as a one off event, whilst doing the initial top balance? (i realise these should be floated between 3.35-3.4v normally.)
A lot of other methods discussed, seems to be to speed up the process. If 'time' isn't a factor, then a slow 'balanced' rise of all cells up to 3.6v over a few weeks would appear to be 'safest' for the begginer?
Reason i ask, is that i was intending to set this method up and check once/twice per day only.
Anyone care to explain the possible pitfalls in this?
