Ant bms and display connecting
georgia088
Georgia USA
I bought an ant bms and an lcd screen. I have the bms up and going and can configure it via Bluetooth app. However, I don’t see any way to connect the lcd to the bms to get the cell readings and info. I can get the lcd to power up but it seems it has uart connection (I thought it was Bluetooth). There is no uart connector that I can find on the bms. Am I missing something? Is there a way to connect these? Pictures is what I have.
Thanks!
The BMS should have 4 pin connector as shown on right. The supplied cable plugs in here and other end into LCD. The loose black & red wires are for LCD power which I think is 24 to 150V.
Have never used the display. View thru phone or Home Assistant.
I have my display working but it came with a six pin connector on the cable, does anyone know what the name of the four pin connector is so I can order one? (I have it working by carefully pushing contacts onto pins)
Thanks!
Here are the pins for mine, its working. hope this helps.
YES, YOU ARE RIGHT, it seems the 3rd party sellers don't offer the necessary cable to you..
