Warpspeed
Solar Wizard
I built myself a natural gas powered "Frankenstein" tumble dryer about ten years ago. That is what the new heat pump dryer is now replacing.Make your own, build a (insulated?) box outside with racks to hang the clothes, or inside with venting outside (both intake and exhaust) and put a small heater (200W) inside it.
Fully functional Rinnai natural gas room heaters could be bought (at that time) on e-bay for scrap value.
Over time, I bought several for $50 each, and sometimes even less. They still appear occasionally, but not not as often these days.
These have a fully enclosed burner and use a heat exchanger. Outside combustion air has its own combustion air blower and the flue obviously also vents outside.
There is a separate room air blower which blows room air through the heat exchanger.
A bit of measurement showed that both the CFM air flow volume, and discharge temperature were about the same as my resistive tumble dryer
I cannot remember the CFM airflow figure, it was a long time ago.
But as I remember, on low heat the discharge temperature was about 50C.
So in a moment of complete madness, I coupled up the gas heater to the tumble dryer. The 2.4Kw heating element was disconnected and a 240v relay connected in its place. The relay contact fooled the room temperature sensor into firing up the Rinnai gas heater, and it all worked far better than I ever dreamed possible. It all worked perfectly including the cool down cycle along with a massive reduction in electricity consumption.
Natural gas here is very cheap by world standards, so it was a definite winner as far a running cost goes.
It was a very ugly piece of hardware, but the results certainly justified its existence.
The whole mess both heater and dryer cost me under $100 to put together, and it has lasted ten years
