I am planning a system for a conversion van and I'm considering using SOK batteries. A far as I can tell, the steel case is unsealed. They have an IP50 rating, which means they aren't water or vapor resistant. I like the price/specs of the battey and the metal case seems sturdy, but I'm wondering if a steel case is going to be more prone to internal condensation. In a van environment, it's not uncommon to have high moisture in the air and it's very easy to get condensation on surfaces due to rapid temp swings. I'm thinking the risk of this with a metal case could be significantly higher compared to a plastic case.
I'm not saying this would be a huge problem, but air(and water vapor) will pass in and out as temperatures swing inside and outside the battery. Any thoughts on whether this would be a problem at all? I was thinking maybe it would be worth throwing a silica desiccant pack into each housing every couple years just to be safe. Another option would be trying to totally seal the case with silicon or something.
