marcfest
- Mar 18, 2022
- 77
I have the two solar systems ("A" and "B") whose specs are shown below.
I wonder what the smartest way might be to integrate the Bluetti EP unit from system B with system A (without using the Bluetti panels from System B because they are just "splash proof" but not totally rain proof so I only bring them out in emergencies).
My primary goal is enhancing the battery capacity of system A.
Any advice?
Thanks a thousand!
Marc
System A
250V / 100A Victron charge controller
4000W Giandel inverter
4 Battleborn 100Ah / 12V batteries in 2S2P 24V config
10 Mission Solar panels in 5S2P config:
Watts (STC) 345W
Max Power Voltage (VMPP) 33.37 V
Max Power Current (IMPP) 10.34 A
Open Circuit Voltage (VOC) 41.0 V
Short Circuit Current (ISC) 10.92 A
Max System Voltage (UL) DC 1000 V
System B
Bluetti 500 EP Solar Power Generator
2,000W
5,100Wh
PV input 1200W Max, 55-145VDC, 20A
AC Input: 600W Max, 100-264VAC
AC Output: 220-240VAC*3, 100-120VAC*4
In-grid UPS Mode&Flexible UPS Mode(24/7)
More: https://www.bluettipower.com/products/ep500-2000w-5100wh-solar-generator
4 BLUETTI PV350 Solar Panels
Used in 2S2P config
Each 350W
Max. Power Voltage (Vmp): 37.5V
Current at Max Power (Imp): 9.2A
Open Circuit Voltage (voc): 46.5V
Short Circuit Current (Isc): 10.8A
Any advice?
Thanks a thousand!
Marc
System A
Watts (STC) 345W
System B
2,000W
5,100Wh
Used in 2S2P config
Each 350W
