JonahJimson
Hi All,
Helping my neighbour with planning his solar project. He has one of those Generlink meter socket things for whole house backup power, will there be any issues installing a grid tied APSmart DS3-L microinverter system connected at the main panel through a PV breaker?
From what I gather, the main concern is the solar backfeeding into the generator and blowing it up, but that doesn't seem to be an issue since the generator is not able to produce power in a stable or within the right frequency range long enough that the solar would recognize it as Grid, so no reason it would start up and backfeed anything.
But what about the generator power flowing to the solar system through the PV breaker? I know that once Grid cuts out, APSmart will go into anti-island mode but it doesn't sound like it'll actually trip the PV breaker or the AC Disconnect, so since there's no physical isolation, is there a risk of the system being damaged from generator power? If so, can the PV breaker or AC Disconnect be configured to automatically disconnect through the use of CT's or any other solution?
I've read somewhere APSmart won't honour the warranty if they find out you have whole house generators, don't want my neighbor to end up getting shafted if anything happens.
Thanks in advance.
Thanks in advance.
