Hi
I am trying to maybe build a battery box with LiFePo4 batteries or other similar ones.
This would be to run an ICECO portable freezer fridge when needed. Would be using it as a freezer for meats and fish, plus I can use a 12-volt cell car plug to charge phones if needed.
Trying to see if I can make one for less then buying a Jackery or something for this as I do not need an inverter to run other things with it just 12 volts out.
I would like a regulated 12v output so I do not end up with problems.
Would need to be able to solar charge it as well the faster the better. With 200 watts or higher going in for faster charging if possible.
Using two 170 pannels.
I could see making a second smaller one as well to run a 12 volt fan, lights, Radio and so on.
Then maybe a Jackery 1000 or Bluettie 1500 to run a TV and charge laptops.
Thanks
Thanks
