Using SA with rs485, everything works but when you change any data you get a CRC error. The data changes ok. I think the CRC error happens when SA tries to read the changed parameter. Also in my automation (which works fine) you see the CRC errors in the log as shown here: (it says it failed to set but that's not true the values did change correctly) Any ideas ? SA bug ?
