CTD
Hey solar peeps, has anyone ever heard of, or better still used Oulite batteries?
I found these while searching for Gels, and the price is unbeatable.
Bonus points if you can give your thoughts on mixing these Oulite's with Diamec gel's of same capacity (12v 100Ah gel).
Side note, if you zoom in on the Diamec info on battery it gives a CV of 14.4-15V. Not sure that is good advice but I haven't contacted the company in China to ask questions.
OULITE GEL DEEP CYCLE 12V 100AH
LCPC100-12 (12V100Ah/10HR) GEL Deep Cycle Battery Rated Voltage: 12V Capacity: 100Ah/10Hr Charging Instruction (At 25°C) TYPE : Float Charge - Voltage Regulation 13.5V-13.8V. Initial Current 10A-25A TYPE: Equalize Charge - Voltage Regulation 14.1V - 14.4V. Initial Current 10A-25A...
www.bigweibattery.com.au
MODEL DMD12-100 GEL (12V100AH)
12V 20AH Standard Terminal: Bolt and Nut (Lead) Optional Terminal: Threaded insert 5mm stud
diamec.com
