Iirc they are the same as the HES(P) line and at least one member is running one.I was wondering if anyone has comments, experience, etc about the SNRE SEI series hybrid inverters. I am.looking at get two of the 12k units for us market
BUT BE WARNED: For me that long thread ended with an order for two 12kW SRNE HESP, now on my bench, waiting for the swap over from the current set up!This post will you back to a massive thread where we discussed both of them.
Post in thread 'SRNE 12kW IP65 HES and 10kW ASP' https://diysolarforum.com/threads/srne-12kw-ip65-hes-and-10kw-asp.81544/post-1146250
Hesp price seems fine. They are in the engine room, so call it semi conditioned spaceHmmm.
What kind of an environment will they be in?
The HESP might be the better choice if there will be frequent humidity swings.
If they're going in a conditioned space I'd go ASP to save some money.
I'd lean towards the HESP, wish I had some hands on experience with it to say for certain.Hesp price seems fine. They are in the engine room, so call it semi conditioned space
What do you mean modular? For space I have a wall in the engine room about 6ft tall 5 ft wide for inverters.I'd lean towards the HESP, wish I had some hands on experience with it to say for certain.
Have you considered a modular system? I'm sure space is a premium but being able to easily swap components could be worth it on a boat.
Same internal breakers and parallel capabilities?Iirc they are the same as the HES(P) line and at least one member is running one.
A handful of us are running the ASPs with great success.
A system that has individual inverters, mppts, etc. For example, Victron.What do you mean modular? For space I have a wall in the engine room about 6ft tall 5 ft wide for inverters.
Fairly confident.Same internal breakers and parallel capabilities?
I did look at victron. But the cost was more than I wanted to pay as I would essentially need either 6 of the 5000va s plus all.the other equipment. As the 15000vas are only in 230vac, not splitphase, as i need. I have two 50 amp sources and two 50 amp panels. Electrical panel is set up as industrial automation with about 100 breakers, 100 relays and contactors, and 4 plc's.A system that has individual inverters, mppts, etc. For example, Victron.
That should be more than enough space for either inverter. How hot will it get in the engine room?
Fairly confident.
I swear there was a post confirming it but I can't find it. Found it Post in thread 'SRNE 12kW IP65 HES and 10kW ASP' https://diysolarforum.com/threads/srne-12kw-ip65-hes-and-10kw-asp.81544/post-1169520
Edit to add, I know that's just a post but specs and photos also look identical.
Ya, looks same. Buddy bought those for $1500A system that has individual inverters, mppts, etc. For example, Victron.
Fairly confident.
Dang that's cheap.Ya, looks same. Buddy bought those for $1500
Over $700 cheaper than what I could find Deye 12Ks for this summer, and with the recent bricking, looks like that will be the go to inverter.Dang that's cheap.
Will you please send me your sales rep contact infoOver $700 cheaper than what I could find Deye 12Ks for this summer, and with the recent bricking, looks like that will be the go to inverter.
