I looked at 5 and 7 inch oil pipe for MT Solar Mount poles, however the OD is quite a bit different than the 6 inch SCH80 the mount required. 6 inch SCH will just about fit inside the 7 inch oil pipe, about 0.040" difference. It was tempting to use a short piece of 6 inch SCH80 at the tope and weld it onto the 7 inch well pipe. However wall thickness on the 7 inch was considerably less than SCH80.
It would work, however if you saddles or other mounts to fit, you will find oil pipe is in a world of it's own. One other thing is it is not considered structural. You can find the specs online, so might be advantageous to see what might fit it.
There is a reason it is cheap. Around here, they use it for cattle fencing and making gates, works well for that.
Iron Ridge sells setups for 2 inch pipe.. Which has a 2-3/8 OD. I think oil pipe is Sch80, but it won't matter, just thicker walls resulting in smaller inside diameter that the solar won't care about. If you have any concerns about fitting, you could always reach out to
Ditch Witch customer service for advice on the pipe compatibility.
I used stainless steel pipe from a defunct car wash.. its the stuff that guides your car tires into the tracks.. Works great!
