All inverters have Big capacitors accross the DC inputs.
These capacitors will look like a short circuit when you first hook DC to the inverter. The capacitors will quickly charge but in the first moments the current can be huge. The outward sign of this is that you get a big-ass spark when you touch the power line to it. The spark can be big enough to pit the threads on a post. There has been debate on the forum about how harmful this is to the capacitors and the BMS. I don't know about the capacitors or the bms, but I do know that the current can be high enough that the BMS can think it is a short circuit and shut down. (Even if it does not hurt anything, you may have to change your underwear the first time it happens!
The bigger the inverter, the bigger this issue is.... On a 1000W inverter I would probably not worry about it but when you get to 3000W, it is getting in the zone where it is something to worry about.
If you are going to hook up the inverter once and never unhook it, what you do is get a ~10 ohm resistor and put it between the battery and positive cable for a few seconds to pre-charge the capacitors, then you can directly hook up the cable without a spark.
If there is a switch in the circuit, the same thing happens every time you turn it on..... but you may not see the spark.
Even though you can't see it, the spark is almost certainly pitting the switch and the surge may be damaging other components.
One common approach is to put a resister and push button around the switch.
With this, you push the button for a few seconds before you turn on the switch.
I came up with a slightly different arrangement with this:
To get the paper, click on the orange button at the top of this page. This circuit is designed as a disconnect switch that allows the user to pre-charge the inverter capacitors before turning the switch completely on. 26 June 2020 update: At...
diysolarforum.com
