Rburnham11
Hi all.
I'm looking for help with the aolithium 51.2v rack battery settings. I'm using a voltacon 11kw ultra max inverter and have been using it with agm batteries up till now. The inverter has various settings for different lithium batteries like pylontech ect but it wont connect to the bms in the aolithium battery. If i select any lithium settings it goes into alarm mode as no bms connection. I can use the user defined settings and it seems happy enough but am unsure of the best settings for this. As you can imagine aolithium custer support wasn't overly helpful especially due to language being unclear. So questions are, is there a way to have this inverter and the battery bms to work together? if not, using the user defined settings could somebody help choose the best settings for this? I have attached a picture of the adjustable settings.
Any help would be very much appreciated.
Thanks
Rich
Thanks
Rich
