Hi all
Maybe you guys have some insights.
I have a single 18kpv. And 2 EG4 LP4 v2 100ah batteries. All was well and showing up properly on the eg4 website.
Got a 300ah Apexium ready built to add to the system.
Removed both the lp4 v2 batteries and connected the Apexium. Didn’t have to change anything on the inverter and set the battery to lux power over CAN. All good and the monitoring website sees the bms and values.
But,
1. The website doesn’t update fully. Green circles are good, red circles are bad.
And if I look at the app, it shows correctly
So my deduction is that it is reading the info from the bms correctly, but somehow the website is wonky but not the app. The website eventually removes the detailed battery display, that info is from the LP4 v2 btw, and changes the other red circle to 0 values. @EG4TechSolutionsTeam
2. I cannot get battery to battery comms working with the Apexium and the LP4 v2
I have tried the following
A) LP4 v2 as host battery with Apexium as slave along with all the dip switches for bat ids. Apexium was set for battery comms on pylon 9600 baud
B) Apexium as host with LP4 as slave along with the dip switches for bat ids.
So initially the LP4 v2 would trip its breaker and that is due to the pin 3 and 6 that needs to be cut. So I did that and then its breaker would no longer trip.
Yet in either A and B, the inverter/website/app didn’t see the slave battery.
Any ideas? It seems from the documentation that the Apexium and the LP4 v2 use different layouts for battery to battery comms…
EG4 doc
Apexium doc
RS485A and RS485B seem to be on different pins on the different batteries….
Ideas?
But,
EG4 doc
Apexium doc
Ideas?
