kklouzal
- May 17, 2021
- 4
I have a question about the APSystems QS1 and YC600 microinverters.
QS1: https://usa.apsystems.com/wp-conten...th-America-Datasheet_-Rev3.0_2021-02-19-1.pdf
YC600: https://usa.apsystems.com/wp-content/uploads/2018/07/APsystems-Product-Datasheet-YC600-6.29.18.pdf
Both inverters show 'Operation Voltage Range 16V-55V' and 'Maximum Input Voltage 60V'.
My question is, can you attach multiple panels in series up to each channel of the inverter as long as you do not go over the operation and maximum voltage specifications?
Specifically I would like to use 2-3 Renogy RNG-100MB Eclipse panels: https://www.renogy.com/content/RNG-100MB/100MB-Datasheet.pdf
'Optimum Operating Voltage 17.7V' with 'Open Circuit Voltage 21.2V'
Three of these panels in series would make 53.1 optimum voltage and 63.6 open circuit voltage. This way I would have 3 panels attached to each channel of the inverter making 6 panels totaling 600 watts for the YC600 and 12 panels totaling 1200 watts for the QS1.
What are your thoughts?
