I can currently switch power source instantly in my shed from mains power to a 48v system using interlocked contactors, however when switching from mains to off-grid specifically, I'm getting some arc flash on the contacts in the mains contactor. I presume because as the contactors switch, the load side is already energised by the off-grid supply, but I see this is common for contactors regardless.
Consider the following image, ignoring the arc suppressor for now and the lack of wiring showing the interlocking, rest assured they are interlocked.
I was considering using a passive arc suppressor (capacitor and resistor) or 2 (one for active one for neutral) on the mains contactor , but my concern is current flow across it to the mains supply side when I'm running on the off-grid supply. Or am I misunderstanding how the Arc suppressor works and no current will flow because it's a high resistance path once the contactors are fully switched?
Thanks
Thanks
