2 series, 4 parallel might be the best way within the context. Keep the extra panel for a spare. I’m not sure about the shading situation though. There’s shaded sun in the morning and late afternoon.
The avg. total power needed per 24 hr. is about 14,000 watt hours.
(not including recharging the batteries)
Is 2400 watts enough to do it?
What, you're going to draw 14,000 watt hours while the sun shines, plus another <unspecified> amount from batteries at night?
Or, you expect total consumption in a 24 hour day to be 14,000 Wh, whether drawn day or night? In that case, the only extra you need is to make up for round-trip inefficiency of battery. (and charge controller, and inverter if you haven't accounted for that.)
LiFePO4 and other lithium is fairly efficient, don't know the exact percentage lost to heat. Lead-acid is much less efficient, could be just 70% to 90% so requires considerably more watts to recharge what was used. Lead-acid gets noticeably hot when charging at a high rate. I hear lithium does not. With high discharge rate, higher internal resistance of lead-acid means more I^2 R losses.
Summer or winter? Consult an insolation calculator. Might be 5 hours effective sun in summer, 2 hours in winter.
Figure PV panels deliver actual PTC power about 80% of their STC rating (more or less, apparently some brands perform better.)
14,000 / 2 / 0.8 = 8750W (STC) of panels needed to deliver that much power in winter,
14,000 / 5 / 0.8 = 3500W (STC) of panels needed to deliver that much power in summer.
Nope.
Better get more panels.
Or one of these:
Or reduce power consumption.
(not including recharging the batteries)The avg. total power needed per 24 hr. is about 14,000 watt hours.
Total for everything except recharging batteries is about <14,000 watts per 24 hrs.(not including recharging the batteries)
About how fast should the batteries recharge during ~8 hours of sun?Total for everything except recharging batteries is about <14,000 watts per 24 hrs.
(basically <600 watts per hour)
You show a 400W Trina panel.Array to CC wiring question. Technical wiring question for 7 400 watt panels in parallel. These panels are listed as 50.4 VOC and 9.74A. Run is 70ft. 8AWG’s the largest cable I’m aware of using MC4 connectors. 8AWG’s rated at 55 amps. Can someone please comment on the best way to accomplish properly wiring this parallel array with a Victron TR 150/100?
So I kinda need the 7th panel in the equation if possible? Like the 7 panels in parallel?< 600 Wh/hour or 600W average is of course a small number.
Larger number is peak consumption, which your inverter, fuse, BMS, etc. has to carry. and a brief higher starting surge if anything has a motor. Most components tolerate a few seconds surge, but for motors it is about 5x their nameplate current which can be a problem.
Somebody said PTC (real-world power) output of the Trina panel is 300W, which is just 75% of its 400W (STC) rating. This means you need to oversize the array a bit more than you would for some other brands of panels.
~<14,000 is a theoretical number based on ~<600 watts draw, in reality it would be less. 1/2 hour on and 1/2 hour off for small window A/C (500 watts) during the non-sun hours. This would leave the batteries basically drained the next day, how fast should they recharge?So I kinda need the 7th panel in the equation if possible? Like the 7 panels in parallel?
Within about 8 hours if there is 2400 watts of panels and average conditions?
(and the appliances drawing about 600 watts)
~500W running 50% of the time,{during non-sun hours}.Even that would be a bit short of your 14 kWh/day, even in summer
7 x 400 = 2800W (STC)
If Trina panels really only produce 300W (STC) (check the data sheet), then for 3500W you would need 12 panels.
See if you can reduce that 14 kWh/day number, and can it be much less in winter?
Seems high for an RV unless you're running A/C. If it is for A/C, you should find a way to run it only while the batteries are at a fairly high state of charge.
The other think about A/C, is if you park in the sun so PV panels get sunlight, you need more A/C. If you park in the shade, RV doesn't build up as much heat but panels don't produce anything.
If 500W running 50% of the time, that's 250W average x 24 hours = 6 kWh, and that only in the summer. Much better. About 1200W of PV for 5 hours gives you that, so 2400W of panels sounds good.
How much battery? You said 24V, so 2400W would be about 100A. If those are 280 Ah LiFePO4, then charging around 0.4C which sounds reasonable.
Anything you can do like an awning, other shade to keep sun off parts of roof without panels should help.
Some people have a few portable panels they can deploy out in the sun, while RV is parked in the shade.
4 100 Ah 12V LiFePO4 Deep Cycle~500W running 50% of the time,{during non-sun hours}.
4 Battle Born 100ah LiFeO wired to make them 24 volts.
Thanks for you thoughts on this situation GXM.I agree, you need to series in at least pairs. Can you fit an 8th panel? 7 is a tough number being a prime, 6 or 8 allows a few options, 7 does not. All in parallel comes out to 68 amps. That is a lot of current, especially at just 41 volts. You would need to run 3 full runs of #10 or #8 wire. Is the shading predictable? Will some panels never be shaded while others will always have shade pass across? Panels that are in series should see the same shading at the same time. If one is shaded, and then later the other is shaded, it is a problem. With 6 or 8 panels, you could parallel the panels where the shade will pan across, and series that group with another parallel group that has the shade pan across. This way the amount of full sun panels in each of the series sections is about equal. And you might get a bit more total energy if you parallel in that 7th panel on the group that usually sees a bit more shade. That would be 4 in parallel with some shade, in series with only 3 in parallel but with less shade. Not ideal, but it could work well. This does limit your maximum current to about 3P or 34.09 amps. That is too much for #10, and borderline for #8. I would probably run 2 runs of #8 to reduce losses on a 70 foot run. Your voltage doubles to 100.8 VOC and 82.2 VMP. Those seem well in range of an MPPT 150|100 with nearly 50% voltage headroom. You did not mention your battery voltage, so I can't tell if your current is safe. 400 * 6 = 2400 watts max (The 7th panel in this setup can't really make more power, but it could extend the time you get full power with one of the parallel panels being shaded. On a 12 volt system, 2400 watts would be 200 amps, not good. On 24 volts, it is 100 amps, so just making it on the 100 amp rated controller. At 48 volts, it drops to just 50 amps so you would have room to spare. You would have to look up to see if the Victron is able to handle over paneling on the 12 volt setup, the 24 and 48 should be completely fine.
8 AWG, supporting 35A @ 82 volts V(mp) on a 70 foot run loses around 4.6% in wiring losses (AKA "Voltage Drop", the SCC receives only 78.1 Volts of difference.) 6 AWG would lose about 2.9%, at rated panel output. The number of strands creates small differences in these figures. I don't know if you need type UF, or whether everyday building wire will be OK. 70 feet seems like a kinda long run.Thanks for you thoughts on this situation GXM.
Each 400W panel has #12 (12AWG) factory wire (~4.6’) in MC4 connectors.
You think it’s ok to have 1 string of 4 in parallel (using #12 or #10 wire for the leads?) in a set of 4 to 1 MC4 branch connectors and one string of 3 in parallel with (#12 or #10 wire for the leads?) in a set of 3 to 1 MC4 branch connectors, and then use 2 sets of #8 to make the 70 ft. run?
(9.74 amps per panel and #8 wire is rated at 55 amps)
