I just had a system installed in the field to provide water to the pond. The issue I have is that the installer didn't provide the information on what he installed. So I could later upgrade if needed. The following images are what I have.
I assume that this is an inverter as it only has the connections from the panels and is connected directly to the pump.
My panels are as follows;
4- 330 W rated at 39.10V each @ 8.4A
My question is this, if I wanted to add battery backup, should I have a
SOLAR CHARGE CONTROLLER then connect to the panel shown above?
We are trying to fill a 50'w X 100'L X 15'D pond
Thanks
Thanks
