Astronergy 325w Solar Panel pallet 30X , $3,300
lolailando
Shipping to many States is aprox $450 per pallet.
We are also planning a few trips in different directions and can deliver with our trailer if it is a few pallets for cheaper, just send a mesage.
Astronergy CHSM6612P-325​
This are PERC panels, so they show as polycrystaline, but this is a completly different method that the old poly panels, these are high end productione units you can read about all the new types of silicon productions here: https://www.cleanenergyreviews.info/blog/most-efficient-solar-panels
DC Electrical Characteristics​
  • STC Power Rating 325W
  • PTC Power Rating 295.5W 1
  • STC Power per unit of area 15.6W/ft2 (168.0W/m2)
  • Peak Efficiency 16.8%
  • Power Tolerances 0%/+3%
  • Number of Cells 72
  • Imp 8.95A
  • Vmp 36.31V
  • Isc 9.1A
  • Voc 45.82V
  • NOCT 46°C
  • Temp. Coefficient of Isc 0.05%/K
  • Temp. Coefficient of Power -0.41%/K
  • Temp. Coefficient of Voltage -0.143V/K
  • Series Fuse Rating 15A
  • Maximum System Voltage 1000V
Mechanical Characteristics​
  • Type Polycrystalline Silicon
  • Output Terminal Type Multicontact Connector Type 4
  • Output Cable Wire Gauge 12 AWG
  • Output Cable Wire Type PV Wire
  • Output Cable Wire Length 45.3in (1,150mm)
  • Frame Color Clear
  • Backsheet Color White
  • Length 76.9in (1,954mm)
  • Width 39in (990mm)
  • Depth 1.6in (40mm)
  • Weight 51.8lb (23.5kg)
