Hey there,
My first post. I'm planning my system for my tiny off grid cabin. It is wired for ac with a regular distribution panel and circuit breakers. Currently the panel is fed directly off my Honda 2000 generator.
I'd like to make a battery bank and inverter system to power my cabin during the day then charge batteirs with Honda during the night. No solar at this time yet.
The main component will be an ATS. This is the one I bought https://smile.amazon.com/dp/B00153EYTO/ref=cm_sw_r_cp_apa_i_asPlFbKWARZ3Z
My plan was to hook it up in a way where when I plug my generator into the system - it will send power to both my ats and my iota battery charger at the same time so my ats will send the power to my panel but the generator will also charge my batteirs at the same time. What I realized that this might cause my generator to overload and shut down if the demand from both the iota and my panel (running chest freezer and super effiecnt ductless ac among other things) is too high as I am not sure what demand is my iota battery chargers (dls30) will demand for charging batteries but I am assuming a lot of power?
Any notes?
My battery bank will be 6x 6v agm 210ah connected in parallel and series creating 12v 630ah bank.
FYI my ductless ac takes about 300watt to run. I'll check later on how much my fridge demends but since it is a chest conversion I'll assume not much..
Any notes?
