DLTooley
- Jan 12, 2020
- 147
Ok, I have a modest 4s 280ah bank with a dumb Daly 60/30 bms with a ten gauge p-. My inverter is a 600 watt GoWisthat has a lead acid low voltage activation of 10.6 which is way to low.
I don’t think there is a simple solution to this, but if anyone has any tips it would be helpful.
The critical load is a 250 watts, an oxygen concentrator that will run all night. That’s not a problem from full, but most certainly could be from less than a full charge.
I’ll check the wiring chart on 250 watts, but I don’t think the p- on the BMS is going to be any sort of safety improvement.
Could a Victron Smart Shunt be used to cut off power at a programmed voltage?
