Automatic transfer switch question
BennyBoops
Marshall Nc
I installed a TS-30 Automatic transfer switch in my Rv following will prowse’ instructions on YouTube. I have the output of my eg43000 inverter(running off one 5kw 48 volt battery) going to the transfer switch to come on when Shure power is not available. My question is how can I charge my battery bank off of just shure power through the inverter input and not charge itself when the inverter is running the Rv
Thanks for any feedback
-BennyBoops
I don't understand your question.
The EG4-3K has a built-in transfer switch that will charge the batteries and run your loads at the same time.
When you unplug from shore power it will automatically switch to batteries.
You should not have needed the additional transfer switch.
-BennyBoops
