T Tamabrey New Member Joined May 7, 2022 Messages 1 Jun 2, 2022 #1 Is there a way to use an automatic transfer switch to power some loads to a house from a eg4 6548 inverter w a 48v life program battery setup?
T timselectric If I can do it, you can do it. Joined Feb 5, 2022 Messages 18,438 Jun 2, 2022 #2 It has a built-in transfer switch. I'm not sure what you are asking.
ncsolarelectric Engineering Support CEO Joined May 24, 2022 Messages 756 Location Statesville NC Jun 2, 2022 #3 Tamabrey said: Is there a way to use an automatic transfer switch to power some loads to a house from a eg4 6548 inverter w a 48v life program battery setup? Click to expand... It has a transfer switch. You'll need a sub-panel, and then you'll need to relocate the loads to this panel to be fed by the new inverter.
