Same question for the Overkill 8s - 100A BMS?
I need to order some 5/16" ring crimp terminals and those balance leads in the photos seem very small???
Thanks
I think they are 26awg. Under the tools section in the manual it states: "Wire strippers, capable of stripping 26 AWG, Klein Tools 11057 or similar (needed to strip the balance leads.)" Soooo.....
Everything you need to know is in the manual. RTFM.
The reason they are small is because they don't need to be bigger. They are only used to measure voltage and the balance current is tiny....I think 70ma's. I soldered my ring terminals. If crimping you can fold the wire over before crimping.
