D dktool New Member Joined Feb 22, 2024 Messages 74 Location Covina, CA Apr 2, 2025 #1 Should the balance setting typically be set to while charging only ? Also, are the start and delta values typ ? See pic
4 42OhmsPA Who likes Electrical Gremlins? Joined Feb 17, 2022 Messages 10,176 Location Pennsylvania Apr 2, 2025 #2 No. Turn it off so it balances on charge, float and discharge. Increase balance start to 3.42V-3.45V. I'd also decrease the delta.
D dktool New Member Joined Feb 22, 2024 Messages 74 Location Covina, CA Apr 2, 2025 #3 What delta value would you recommend ? Last edited: Apr 2, 2025
4 42OhmsPA Who likes Electrical Gremlins? Joined Feb 17, 2022 Messages 10,176 Location Pennsylvania Apr 2, 2025 #4 I run as low as the setting will take. Really 15mV is fine but I feel decreasing allows better balancing.
D dktool New Member Joined Feb 22, 2024 Messages 74 Location Covina, CA Apr 2, 2025 #5 Thanks, I did this; Attachments Screenshot_20250402-185709_Overkill Solar.jpg 79 KB · Views: 10
4 42OhmsPA Who likes Electrical Gremlins? Joined Feb 17, 2022 Messages 10,176 Location Pennsylvania Apr 3, 2025 #6 dktool said: Thanks, I did this; Click to expand... I'd also increase charge under temp above freezing, 0C or a little higher.
D dktool New Member Joined Feb 22, 2024 Messages 74 Location Covina, CA Apr 3, 2025 #7 So zero on trigger and leave release at -5c ?
4 42OhmsPA Who likes Electrical Gremlins? Joined Feb 17, 2022 Messages 10,176 Location Pennsylvania Apr 3, 2025 #8 Release higher than trigger.
D dktool New Member Joined Feb 22, 2024 Messages 74 Location Covina, CA Apr 3, 2025 #9 So zero and +5c ?
D dktool New Member Joined Feb 22, 2024 Messages 74 Location Covina, CA Apr 3, 2025 #11 This is the first time (already) that all cells are perfectly balanced, cell #3 was always slightly lower than the others, I just thought it was a little lame. Now it is in step. Last edited: Apr 3, 2025
