My BattleBorns arrived in 2 days from Reno and showed identical voltages (13.24V), confirming factory balancing.
I figured I didn't need any balancing and was ready to wire these up in series. However, I thought it would be good practice and I wanted to learn about my hall effect sensor and practice with some XT connectors...so parallel'd em up with 4AWG.
Does it take forever and a day to actually reach 0.0 amps OR am I just seeing the +/- 0.3A variation stated in the sensor "manual"?
Multimeter on amperage DC shows 0.0 current passing. Recalibrated, reset Bayite Sensor and I still show 0.2A.
Normal variance? What is close enough to consider fully balanced?
Is a decent multimeter the most accurate way to get true readings?
