mkpieters
- Nov 28, 2019
- 38
I am having a difficult time balancing my prismatic cells. i first connect all + and all- for a day so they can equalize i then connect in a 4s 12 volt configuration and put a load on them to drain down to about 3 volts. once they are all about 3 volts i then charge them up. at first all is great all the way up to about 3.35 to 3.40 volts that is when there always is one cell that shoots up to 3.65 volts and of course the BMS stops the charging.
what am i doing wrong? should i discharge down lower when balancing?
thanks
thanks
