bostonbuzz
- Jan 13, 2020
- 52
I hooked up my Chargery 8T BMS with 1.2A of balancing to a 4s series of 280ah xuba batteries which were within 5 or 6 mV out of the box. I charged with a victron ip67 12/13 charger at 4a for a day and found over 300mV difference between cells! Obviously I either have 2 bad cells or I need to do initial balancing. Unplugging the charger slowly brings the cells back in balance overnight via the BMS.
I have placed them in parallel since I have no power supply and plan on waiting a few weeks with the cells in parallel. Do I:
1. Keep in parallel and just disconnect them from each other every day or so and check if they all stay at the same voltage after an hour (not sure this is the proper procedure)?
I have a Klein CL380 clamp meter for this, is that accurate enough?
2. Reconnect them in series and set my bms to balance in all states (charge/discharge/storage) down to 1mV (the highest accuracy of the chargery)?
3. Charge to 3.65v in parallel like Wills video suggests. I can’t do this without buying a power supply. I suspect a whole lot of lurkers and members don’t want another component lying around either.
Which method (1 or 2) would get me closer to the gold standard of top balancing to 3.65v in parallel (#3)? Would 1 or 2 achieve what #3 achieves just slower, or is it never as balanced?i
How long would the have to stay at the same voltage by chargery (or just sitting in parallel) before they were “balanced” (because voltage is not indicative of SoC).
