If have a LFP system on my boat, made from bare cells. I have separate load and charge busses, a REC BMS for cell balancing, high/low voltage alarms, high/low temperature shut down, and very high/low voltage disconnects.
I have a completely separate charger control that enables charging (below 20% state of charge or when charge cycle is triggered manually). The charge controller disables all charging when LFPs are fully charged based on voltage and residual current. Existing charge sources are engine alternator, shore power charger, and wind generator. They are all configured to deliver maximum current up to 14.1 volts and then hold that constant voltage as the current declines. The charge controller disables all charge sources (safely) when the charging current falls to a defined level. All good so far.
I now want to add a solar charging source. Like the other charge sources, I want the solar to deliver maximum current up to 14.1v, then hold the voltage at 14.1 as current declines until the charge controller shuts down all the charge sources.
I guess I really just need a 14.1 volt solar regulator or a charge controller with 14.1volt absorption phase and no float phase at all.
Question #1 - Does such a thing exist? Can such a regulator be MPPT without any charge control?
Question #2 - I have four 12 v, 100 watt Bouge RV CIGS Panels and one 80 watt Lensun 18 volt panel. What is the best way to set these up for the charging behavior I am looking for?
Thanks for any advice
