Hi, Since I am doing a 48-12v to connect my 48v system to RV, some parts of my needs are not covered by the blueprint.
I wonder if you need a bus to connect all the cables or screw everything to the battery terminal?
Another issue is that a smaller device, such as led lights, may only need an 8 AWG or even 16 AWG cable; if I use a small connector to it, it will not go through the screws. Is it ok to crimp a bigger connector to a small cable to be connected?
Is the insulation from election tape is enough? I felt it was so thin, and I have some cables so close between positive and negative.
Following is the picture of my work, thank you!!!
