callmeburton
- Mar 4, 2022
- 347
Anyone play with the ramped charging yet?
I have a SMA SI I am going to use as my remote, it has max Amp charging settings for gen and grid tied sources. Since I am going to have both my grid and gen go into AC2 ( which is the GEN input ... see thread here: https://diysolarforum.com/threads/i...bank-and-sma-si-load-center.52698/post-670976 ) I am going to change these SMA SI settings to max out for what the generator is rated for so the SI knows how much of the loads it can shift to AC1 when required vs the previous bulk only charging settings.
I have been reading the threads in relation to charging profiles re:LiFePO4 and was going to start modifying the ramped charging settings on my own rig before connecting it to the inverter and was curious if others have done yet and what settings you might have used.
