callmeburton
- Mar 4, 2022
- 347
from that document "AXITEC AXIstorage Li 8S QTY 3 or more for offgrid with splitphase" That is ~22kW of storage. 3 of my 280 batteries is ~32kW of storage.
I have not had this device hooked up to any computer or the web for months ... it was "working," with previously mentioned issues, for that long in my new offgrid setup :/I've had that happen with software/firmware updates and there was a software/firmware update in the last few weeks. I don't know if there is a setting for automatically updating, I choose when I do mine.
Just tried this .... I suspect i did some settings by my charging was defaulted ... and when I select ramped all options are zeroed out >__<There is a backup file on your laptop used for the toolkit, it will revert your settings to what you had.
Then it wouldn't be the update that caused it. I do recall one time I did the update and did not know how to use the backup file (still have a hard time with using the backup file and remembering how to do it) and it reverted to factory default settings. That caused the breaker to trip as I run custom settings. That sucked big time, I feel for you. It took some time to get settings back to where I thought it should be set.I have not had this device hooked up to any computer or the web for months ... it was "working," with previously mentioned issues, for that long in my new offgrid setup :/
How so?Yeah the comm's is a must for SMA with any LFP batteries :/ ... it is pretty though.
without comms going to the SMA from a BMS hooked up to the LFP the SMA SI will not run :/ let alone charge when asked to. The whole unit will turn itself off right now and restart when the comms drops for a second (one of the current issues with the batrium I have)How so?
My REC setup does that too. Not that often though. Maybe once every two weeks on average. Although that’s an average. Might happen twice a week or go a month without doing it.without comms going to the SMA from a BMS hooked up to the LFP the SMA SI will not run :/ let alone charge when asked to. The whole unit will turn itself off right now and restart when the comms drops for a second (one of the current issues with the batrium I have)
You can use vrla settings with lfp. I've been doing that since December and haven't had a single issue.without comms going to the SMA from a BMS hooked up to the LFP the SMA SI will not run :/ let alone charge when asked to. The whole unit will turn itself off right now and restart when the comms drops for a second (one of the current issues with the batrium I have)
That's not good enough. I recommended it before and I'll do it again- consider just using voltage. You have a generator. Set it up so the generator comes on a at say 30% soc and you should not have any issuesMy REC setup does that too. Not that often though. Maybe once every two weeks on average. Although that’s an average. Might happen twice a week or go a month without doing it.
Do you have a link to a thread with your current settings? I assume your doing LiFePo4 in 16s and some number of those in parallel ...You can use vrla settings with lfp. I've been doing that since December and haven't had a single issue.
I use 2.36 (56.6v)for full, equalization and boost, 2.30 (55.2v)for float. You can adjust to your settingsDo you have a link to a thread with your current settings? I assume your doing LiFePo4 in 16s and some number of those in parallel ...
And I assume the SI would have no clue, open loop, that a individual battery is beyond its limits and not know when to stop charging?
My BMS just monitors the cells and makes calls for charging or takes action when certain conditions are met. Shouldn't need coms to do that.I use 2.36 (56.6v)for full, equalization and boost, 2.30 (55.2v)for float. You can adjust to your settings
My bms (jk) does not require communication to do it's job. Does yours?
What size is your battery? 30a is very little.My BMS just monitors the cells and makes calls for charging or takes action when certain conditions are met. Shouldn't need coms to do that.
But I know if I throw more than 30 amps into my battery my cells will spike and the BMS normally would call to halt charging to protect against over voltage of an individual cell. With COMMS it is able to do this but I suspect the SI wouldn't be listening to the BMS COMMS if it is set to VRLA?
I will break out the book and flip through the settings for VRLA and maybe run a test ... the BMS will simply disconnect the SI's if things get really bad but I prefer that not be the case.
EDIT: I should add ... the batrium doesn't bleed excess voltage off cells as easily as the REC does ... it really is not designed for LFP :/
280ah, all eve cells, when one spikes above 2.65 if I recall correctly the BMS disables charging. 30amps is the setting, the SI will spike it up to like 50 for a moment or two before ramping down to 30. If I had it set to 50 it would ramp to 70ish ... the ramping when it first starts charging causes cells to spike as well ... I have a thread about it somewhere if not in this thread.What size is your battery? 30a is very little.
I won't pretend I know how your bms works but 30 amps at 50v is about what-.1c ? There shouldn't be spiking going on. The closed loop comms is causing trouble. Try Switching to open loop, set the sunny island to 3.45v or somewhere differently below your 3.65v threshold on your bms then you wouldn't have issues280ah, all eve cells, when one spikes above 2.65 if I recall correctly the BMS disables charging. 30amps is the setting, the SI will spike it up to like 50 for a moment or two before ramping down to 30. If I had it set to 50 it would ramp to 70ish ... the ramping when it first starts charging causes cells to spike as well ... I have a thread about it somewhere if not in this thread.
If you set a new battery in sunny island it tries to charge it to full immediately .AGAIN! ... 0430 today it looks like the power shut off ... I came in and the BMS again had reset itself to a default state, the battery voltage was about 30% SOC this time.
I reset it all, and reset the SOC the configured the SI for VRLA and started things up to find the SI dumping 6000w into the battery though I set it to only do 50 amps 0__0 ... I turned it all off and figured it out ... I had bypassed the shunt the SI was reading its current from and I guess it just thought "give it all I got" ... I am sure total I was peaking the output of my SB lol
Will let this go a bit and see what happens.
