Tonight I finished my battery capacity test on the Fortune 25ah batteries. Success!!!
I charged the battery up to 14.4v (3.6v each. Then I turned on anything I could.
I had a small 150w 12v inverter - plugged a computer into it.
Had a 12v fan and a 12v LED light - with all that stuff I was using about 60watts - 5 amps... OK this is going to take a while. Started on Sunday evening. When I went to bed took off all the loads. After work put them back on. Are we done yet... (Note to self... make sure you have a real load if/when you test the eight 280ah batteries). Finally, got into the lower knee and one cell got down to 2.75v the others were 2.76 to 2.77v, so my Watchmon4 went critical, and the contactor shut off, 1 sec later turned back on, two seconds later shut off. I took all loads off, and about that time it turned back on. Started to charge it back up.
I was using the Batrium software to track the Ah used. I had used about 51ah. I didn't charge to a max 100% 14.4 volts (3.6v) instead of 14.6 (3.65v) and I shut off at 11v (2.75v) instead of 2.5v. So a little more that stated capacity. I am happy. I figure I will charge up to about 50%, then I will finish this portable battery. I have everything for it.
The Fortune 25ah cells are very well matched and stayed in sync all the way up and down. Very happy with them.
