My gen1 (round) screen srne10k overcharged like this sometimes also, didn’t matter if comms were enabled or what inverter settings were, my batts would eventually disconnect. This would happen more often when I had alot of PV coming in and not much load. I added more circuits to my solar panel ( I put every ceiling fan in house on the solar circuit and left them on all day) I also added several other inductive (coil magnet) loads like my wife’s backyard garden waterfall pump, it use to be on a timer, I just let it run all day. After I put more loads on the inverter it got better about throttling down all the pv power coming in. It’s almost like it couldn’t find anywhere to dump the power so it was over dumping into the batts. That gen1 eventually had a board failure tho, this gen2 doesn’t do that. I hated that round screen srne10k.
Put more load on the inverter and see if it keeps “leaking” so aggressively to batts
That’s the only way I could stop mine was by loading it up more during peak hours
Do you hear the machine “whine” sometimes? Like capacitors singing abit, a very high frequency? Almost like you can’t hear it? Mine started doing that before the power board went
