Hi there. I need some help figuring out what I need to upgrade on my system. At the moment I have 1x 480 Watt Canadian solar panel (46V output) hooked up to a 60A 24V charge controller and 2x 105ah 24V Lead Acid batteries. From the batteries I have a 2000 Watt Inverter powering 4 lights outside and my Computer which uses just over 1000 Watts of power. I've noticed during the day my battery voltage keeps dropping slowly if I only have the solar panel charging my battery.
If I hook up my inverter to the grid the voltage stays at about 25 so it's either my solar panel or charge controller that's not charging my battery fast enough? But I'm not sure.. And I don't want to buy another panel if it's something else. Is there some way to determine what is the issue?
Thanks
Thanks
