Repro
I was in contact with a well known dealer for a VE Quattro 5000 48V. See the transcript below. I was floored. I did redact some of the content to avoid any problems. Please give me some feedback. I am a little shaken by the recommendation given to me.
(06:20:58) | *** Repro joined the chat *** |
(06:20:58) | Repro: Interested in VE Quattro 5000 48V. Do you help in programming? Would need to set it up for self consumption mode. Only use grid power to charge batteries when solar can't keep up, and battery voltage hits 48V. I have four 12V 200Ah LiFePO4 batteries, a VE 150/70 controller, Cerbo GX, 500A SmartShunt and battery SmartSense module. My heaviest load is 2900W if everything would turn on at once. Normal load is less than 1000W. Can you help me? |
(06:22:30) | Customer Service: We apologize for keeping you waiting. Our sales/tech reps are busy at the moment, please be patient for another minute or so, or if you prefer to leave your email we will contact you as soon as possible. |
(06:23:15) | Repro: |
(06:24:19) | *** Customer Service joined the chat *** |
(06:24:59) | Customer Service: It's easy to configure. We can walk you through it or connect to it remotely if you have a Cerbo. |
(06:25:08) | Customer Service: Have you purchased all of your equipment? |
(06:25:53) | Repro: All I need is the Quattro and the MVK3 adapter. The rest has been in use for about 6 months. |
(06:27:00) | Repro: I also have a 40A dedicated AC line running from my breaker box to the space where the inverter will be installed. |
(06:28:38) | Customer Service: We can talk you through the AC Input Control Settings. |
(06:28:53) | Repro: I was in touch with VE. They recommended you. |
(06:28:57) | Repro: Sounds great |
(06:29:37) | Repro: OK, I will have to order the Quattro. Would you recommend the 48V version with my battery bank? |
(06:30:06) | Customer Service: What kind of batteries do you have? |
(06:30:44) | Repro: four 12V 200Ah LiFePO4 batteries from Ampere Time. They have a 200A BMS. |
(06:32:01) | Customer Service: I would never recommend series lithium batteries with an internal BMS. You can consult with the supplier or manufacturer of these batteries but rarely is this a good idea. |
(06:33:16) | Repro: They can be connected either 4S or 4P or 2S2P. |
(06:33:37) | Repro: That is from the manufacturer |
(06:33:52) | Repro: I can do 12V, 24V or 48V |
(06:34:26) | Repro: I am skeptical about connecting 12V to a 5000VA inverter. |
(06:34:40) | Customer Service: Yeah, I would be too... |
(06:34:52) | Customer Service: taht's a lot of power for a 12V system. |
(06:35:08) | Repro: Do they sell a 24V Quattro? |
(06:35:30) | Customer Service: Yes Sir. |
(06:35:44) | Customer Service:
Victron Energy Quattro 5000 Watt 24 Volt Inverter & 120 Amp Battery ChargerPart Number: QUA245023110 Note: To do advanced Inverter configuration and setup you must have a VE.Bus To USB MK3-USB Interface.
www.solar-electric.com
(06:35:45) | Repro: Would you think that would be OK? |
(06:36:04) | Customer Service: I didn't say it wouldn't be OK to do the 48V. |
(06:36:14) | Customer Service: You asked for my recommendation. |
(06:36:34) | Repro: So you would recommend using 48V batteries. |
(06:37:27) | Customer Service: I don't recommend series 12V lithium batteries. No reputable manufacturer or application engineer would recommend one series 12V lithium batteries for applications with cyclical operation. |
(06:38:16) | Customer Service: Yes, exactly. One would want to use a 48V battery (with internal BMS) for applications that require a 48V inverter. |
(06:40:37) | Repro: OK, I thank you for your recommendation. I have a dilemma here, I have $6000 in new batteries and need an inverter with 4000-5000 watt capacity. I feel insecure about the safety of using these batteries in that capacity now. |
(06:41:00) | Repro: I am going to have to rethink my options and get back to you. Thanks! |
(06:42:49) | Customer Service: Happy to help non the less... and will always be honest when someone asks for "my" recommendation. Sorry I put you in a dilemma. |
(06:43:00) | Repro: Thank you! |
(06:43:07) | Customer Service: Welcome. |
(06:43:13) | Repro: Have a great Holiday weekend. |
(06:43:24) | Customer Service: You too. |
