Bluedog225
Texas
- Nov 18, 2019
- 2,897
Good morning,
I have two battle born 100 amp 12v batteries and 300 watts of solar (parallel) at 12 volts.
Am I better off installing switches that will allow me to separately charge and use each battery independently? Or go ahead and parallel the batteries and use them as one battery bank?
I’m really indifferent from a set-up standpoint. But I sense some issue with parallel batteries and keeping them in balance over years of service life that I’d rather not mess with. Or I need to understand it better.
If I go down the path of using them separately, is it useful to distinguish between charging them separately versus independently and applying load to them separately versus independently? That is, do the parallel concerns only arise during use and not during charging? Or vice versa?
Thanks for any thoughts on this.
Edit-I have seen many of the “different batteries” in parallel threads. Since these batteries are theoretically identical, I wondered if there were a best practice to follow before I set them up. Thanks
