Battery balancer won't balance
Greenan_Energy
I've got the balancer below and it won't seem to balance. When I go to balance it only seems to flash 5s and does nothing. Have anyone any ideas on what to do. Thank you
No image of the balancer was attached to the message.
They were all in balance but I've drained the battery to 24V and now out of balance of about 0.05V at the very most.
Yeah it's all within range. The only example I have of it working is from Will Prouse video where he balances his battery with the blue balancer. I'm not sure if his one is an older version and indicates different when it's balancing.
This is what I get up when I follow his instructions.
If you must force a balance cycle, place a power resistor across one cell to drain it down 20 our 30 mv. Then remove the resistor and initiate the balance mode.
NOTE: You may need to pull it down 40mv so it will remain 20-30mv lower than the others when the resistor is removed.
