Electrobob
I have four 12v 100 ah batteries wired in series parallel, connected to a 24v mppt. I know when you have multiple batteries wired together they can become unequally charged through charging/discarging cycles. People say you should charge each battery to 100% individually once in a while, but I know alternatively people will let batteries sit wired in parallel so they balance against each other and therefore stay in sync. My question is: since I have only 2 batteries in each series and then both sets of two are connected in parallel, won’t they all balance out together after a charge just by sitting there wired in parallel and avoid the issue of getting out of sync with each other? Is separate battery charging really necessary when wired in this configuration?
