My system info: (1 month old new system)
(8) 270watt solar panels
100 amp Epever Charge Controller
(8) Duracell GC2 6V 230AH lead acid deep cycle batteries .
3000 watt inverter with 24v input.
All cables are 0, to 2 guage copper strand cables.
Batteries hooked to 2 strings of (4) 6v Duracel GC2 230AH batteries in serial to 24V.
Solar Panels hooked 2 panels to a string in series to get 80v. Total 4 strings going to combiner box before connecting solar charge controller.
From 10:30am to 5:00pm, i am getting 1,600watts from panels. During the day, my power usage is less than 500w to 700w at any giving time so charge controller always have power to charge battery bank and usually thinks my battery bank is full around 2pm (27.5 to 28.25 volts) and goes into float charge mode until night time.
Once night time comes around 8:45pm, my batteries voltage dropped from 27v to 25.5v which is supposed to be 100% charge. Using my single phase 120v well pump (450 watt using a killawatt meter) for 10 minutes and stopping it, battery voltage drop to 25v which is around 80% capacity according to most charts.
How can i drop from 100% charge at 25.5v to 80% charge at 25v using 450watt for 10 minutes. My battery bank is 460AH at 24V, which is around 11,000 watt hour.
Are my batteries defective ? Is there a flaw with using battery voltage to determine battery capacity ? The battery indicator on my Epever is useless because it will be 3 bar after dark from 100% full at 5 bars. I have a battery monitor with a shunt from amazon for around $50 but it lose track of my battery capacity once charger starts charging. The voltage is displayed correctly. Just not capacity.
System voltage is correctly measured and displayed from inverter, charge controller and my battery monitor.
With my normal enery consumptions over night, i end up with around 24.2 to 24.5 volts in the morning which is around 50%. According to my battery monitor, system used 70 to 80 amps overnight. If so, that is less than 25% of my capacity, yet based on my voltage, i am close to 50%.
