I am using a charger. That is bad?
Shoemaker 8 amp charger I have 2 of these but I am using only one now.
Probably OK at least temporarily if it follows the proper voltage profile: Constant current up to a particular voltage, constant absorption voltage for a few hours, then drop to float voltage.
But the battery spec sheet called for minimum 15A charge per 225Ah battery (or series string of 2 6V batteries making 12V)
So with 2s4p batteries, it calls for at least 60A charge current.
You ought to put in enough PV for the recommended charge, 1000W of panels or more, and an SCC of at least 60A.
Note that you have enough batteries to wire for 24V or 48V system, reducing minimum charge current to 30A or 15A, which can be done with a less expensive SCC.
"Right now I am totally DC. I have a little Coleman DC cooler and it seems to run well using 4 to 7 volts. I do not know how to use a tester to measure amps.
I have the emergency DC lights available.
I guess my ambition to run a 12 anp deep freezer that runs on and off ( compressor doesn't seem to a lot)
So, is it possible that when I move to AC will be able to get a general idea of weather or not this configuration will run fluently?"
"DC Cooler" - is that a solid-state thermoelectric "Peltier" cooler? Don't run that off batteries - draws far too much power, very inefficient.
Make a 24V or 48V system, and buy an inverter to run off that. Use a DC-DC or AC-DC charger to keep 12V Marine/Deep Cycle batteries charged for 12V loads. Batteries are the most expensive part of a system, and you already have AGM batteries. Just buy a 48V inverter, inverter-charger, or hybrid. You could spend anywhere from a few $hundred to a few $thousand depending on the brand, quality, capability you want.
