Battery Case
emeraldcoastcamper
First let me say that this forum and especially Will's videos have been a game changer for me. I have ordered 4 CATL 3.2V 200ah batteries and a 12V LIFEPO4 SMART BMS W/ LOW TEMP CUTOFF . My aim is to place everything in a case with top terminals. The only cases I have found are on Ebay for $10.00 but the terminals look so cheesy. https://www.ebay.com/itm/32650-LiFe...a=1&pg=2334524&_trksid=p2334524.c100667.m2042
My installation will be inside my Airstream trailer. Anyone have a source to reccomend?
Here’s some China battery boxes.
Many different sizes. If you scroll down thru ad. Long shipping times though. ✌
US $46.00 | GTK lithium battery box 12V 24V 48V 100ah 120ah 150ah li ion lifepo4 LTO battery ABS+PC battery empty case
Thanks a bunch. Don’t know why they did not come up in my search. Too bad there isn’t an America based supplier for the components we all need.
Has anyone seen larger cases like this one that could fit the 280Ah or 200Ah (or 150Ah) aluminum cells?
The dimensions for the 280Ah cells are 174mm x 72mm by 205mm high
The dimensions for the 200Ah cells are 175mm x 55mm by 205mm high.
If I went with the 150Ah cells, I might go 2P4S and those are 174mm x 48 by 171mm high
Nevermind - I found some through BLS.
