HappyCampers
Hi All, I'm hoping someone will be able to help with our MT50 Charge Controller and the correct charge parameters.
My partner and I are travelling around the UK in our Camper van and have recently upgraded the single 95AH battery to two 120AH batteries (NUMAX XV35MF 120AH, connected in parallel), The MT50 remote controller from what I've worked out only allows me to change the parameters if I select 'USER' in the battery type section. Unsure on what would be a safe selection for the remaining parameters on these type of batteries... Any help would be appreciated as I'm having no such luck receiving the info from the battery manufacturer.
- Over Volt. Disc.
- Charge limit
- Over Volt. Rec.
- Equal. Charge
- Boost Charge
- Float Charge
- Boost Rec.
- Low Volt. Rect.
- Under Volt Rect.
- Under Volt Warn.
- Low Volt. Disc
- Discharge Limit
- Equalise time
- Boost time
- Over Volt. Disc.
- Charge limit
- Over Volt. Rec.
- Equal. Charge
- Boost Charge
- Float Charge
- Boost Rec.
- Low Volt. Rect.
- Under Volt Rect.
- Under Volt Warn.
- Low Volt. Disc
- Discharge Limit
- Equalise time
- Boost time
