Battery Charger Connection
Daisy
Hi,
I have a 24V Li-ion Battery Box connected directly to a 2000W 24V pure sine wave inverter. I want to charge the battery manually with a 24v Victron charger. Can I connect the charger directly to the same terminals on the inverter and turn the inverter off when charging the battery?
Is that a dumb idea?
Thanks!
Probably.
You used the term "Li-ion," so that creates a lot of uncertainty. Li-ion refers to all types of Lithium chemistry. Charging non-LFP can be a lot more tricky.
